PCAN-USB: Setting GPIO (Labview)
USB to CAN Interface
Anil8899
Post by Anil8899 » Mon 25. Oct 2021, 07:19
Hello ,
I am using PCAN_USB device to set the GPIO by sending CAN message,
problem is when I am sent message to set particular GPIO , but i am receiving other response ID in-between.
could you please guide me in avoid this problem .
response received
response received
Block diagram
Block diagram
Re: PCAN_USB_
Post by PEAK-Support » Mon 25. Oct 2021, 08:12
Sorry - this is a problem in your environment / used module. We do not know what exact you are tlaking about (which GPIO, which ID...?!?)
We could not help you! Also we do not support LabView.
Simply try first with PCAN-View and see / check if the System works as you aspect - after that try it in LabView.
