I've installed PCAN driver successfully, but every time I insert PCAN device into PC USB port and run RAFT v4.37.02 on my Windows 7, it reports failure of J2534, and I can't find a valid device to use. See screenshots in attachment.
Please correct J2534 problem
- In the main window, no valid hardware device could be found.
- main_window.png (35.67 KiB) Viewed 5542 times
- This pop-up window says program has a problem with J2534.
- problem.png (10.93 KiB) Viewed 5542 times
Re: Please correct J2534 problem
we don´t know your RAFT software tool, but it looks like it needs a J2534 PassThru interface. As a first step, please install the PassThru driver from our website, and configure it to your needs.
https://www.peak-system.com/fileadmin/m ... ssThru.zip
