Please correct J2534 problem
Qidi.Huang
Post by Qidi.Huang » Wed 13. Mar 2019, 04:27
I've installed PCAN driver successfully, but every time I insert PCAN device into PC USB port and run RAFT v4.37.02 on my Windows 7, it reports failure of J2534, and I can't find a valid device to use. See screenshots in attachment.
In the main window, no valid hardware device could be found.
This pop-up window says program has a problem with J2534.
Re: Please correct J2534 problem
Post by M.Maidhof » Thu 14. Mar 2019, 10:03
we don´t know your RAFT software tool, but it looks like it needs a J2534 PassThru interface. As a first step, please install the PassThru driver from our website, and configure it to your needs.
https://www.peak-system.com/fileadmin/m ... ssThru.zip
